주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Intel Core i5-12450HX, 최대 RTX 4060 GPU, 15.6형 FHD 144 Hz 디스플레이, 최대 32GB DDR5, PCIe Gen4 SSD, 60Wh 배터리, HDMI 2.1 및 USB-C를 포함한 전체 입출력(I/O) 단자를 탑재한 Lenovo LOQ 15IAX9.
How do I reset BIOS.
When i was downloading GPU Drivers, it said that something went wrong. So i got to BIOS settings and turned GPU from Hybrid to Discrete. My screen went black, never turned on again, fans are spinning, keyboard lights up, just black screen. Tried resetting CMOS battery, tried disconnecting main battery too and also tried hard reset, nothing worked. Can y'all help me? Thanks.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 2개
Turn off the laptop, then turn it on and repeatedly press F2 (or Fn+F2) to enter the BIOS menu. Navigate to the Exit tab, select Load Setup Defaults, confirm with Yes, then select Save & Exit. Hope it works!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I also had a similar thing happen when changing any setting or updating bios, if it looks like it is boot looping trust that because it looped 5, maybe 6 times before the screen lit up for me after a bios update. It's scary but eh, I guess I can deal with it... If it didn't try to restart either your GPU might not be getting to the screen and in that case I'd just hold down f2 during boot and disable discrete mode, it's no use downloading a GPU driver if it's gonna stop functioning...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Giorgi Abramishvili 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 17
지난 30일: 78
전체 시간: 854
