주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1903년에 설립된 영국의 자동차 제조회사가 생산한 차량 수리 안내서 및 지원.
Fuel vacumm line issue
I have a vauxhall astra j 1.4 the fuel vacumm hose has broken on the engine side, is it the intake manifold it connects to? Thanks in advance
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Hard to say, Tony. Most of the vacuum lines are powered from the intake manifold, so that's a reasonable guess, but that's all it is at this point since we can't see the hose you're referring to. Can you add a picture of the hose you're concerned about so we can see what you see?
기존 질문에 이미지 추가하기
의 공유
댓글 달기
답변 1개
Yes, on the Astra J 1.4 the small vacuum hose normally connects to the intake manifold. The intake manifold is the main source of engine vacuum, so most of the small vacuum lines run from there to things like the fuel pressure regulator, purge valve, or other control components.
If the hose has snapped on the engine side, have a close look around the intake manifold for a small plastic nipple or spigot where it would have pushed on. They can sometimes break off if the hose goes brittle with age.
Make sure you replace it with proper vacuum hose (not fuel hose) of the correct diameter, and push it on firmly so it seals properly. If it’s left disconnected you may notice rough idle, poor running, or even a check engine light because of a vacuum leak.
If you’re unsure which port it came from, a quick photo of the area would help narrow it down.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Tony Rose 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 32
전체 시간: 152
