주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
My vibration mode not working
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Check Vibration Settings
  • Go to Settings
  • Tap Sounds and vibration
  • Make sure Vibrate while ringing is turned ON
  • Tap Vibration intensity and increase it
Check Sound Mode
  • Press the Volume Down button
  • Make sure the phone is in Vibrate or Sound mode (not completely muted with vibration off)
Test Vibration Manually
  • Go to Settings > Sounds and vibration > Vibration intensity
  • Adjust the slider and see if the phone vibrates
If there is no vibration at all, continue below.
Restart Your Phone
Sometimes a simple restart fixes minor software issues.
Check Accessibility Settings
  • Go to Settings > Accessibility > Interaction and dexterity
  • Make sure no setting is disabling vibration
Boot in Safe Mode
This checks if any third-party app is causing the problem.
  • Press and hold Power button
  • Tap and hold Power off
  • Select Safe Mode
If vibration works in Safe Mode, an installed app is likely causing the issue.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Not working I think vibration motor not working
댓글 달기
답변을 추가하세요
Deb Mandal 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 4
지난 30일: 24
전체 시간: 150
