주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2021년 10월에 출시된 Google Pixel 6 스마트폰의 수리 및 분해 정보입니다. 모델 번호 GB7N6 및 G9S9B16으로 식별됩니다.
Long term battery storage
I have had my pixel 6 for since 2021 and I love my phone. It hasn't slowed down for me at all and besides the battery swelling up and a cracked screen of my own blunder.
I have since then bought a replacement screen and a replacement battery and i feel as if I'm using a completely brand new phone. I want to buy additional screen and battery to keep for the long run (maybe 10 years of use) before I buy another phone.
What do you guys think the best long term storage of Lithium ion batteries for phones are? I heard some people say leave it at 50% and store room temp. Ive read others store it at 4*C.
If i do need to recharge the battery once in awhile, is there a tool I can use to do this without taking my original phone apart?
I also plan to buy a replacement screen to act as a back up incase i break it again and it is no longer being manufactured; are there specific storage quirks that are associated with storinge phone displays over time?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개
As far as "storing at 4°C", I don't think you have to focus as much on the exact temp as just "cold but not freezing." I've on occasion stored Li-battery-powered stuff in a plastic bag shoved into my fridge (in a place where food residue won't get on it). Worked just fine.
I'd lower the charge down to about 40% or so.
If you have a volt meter and some resistors, you can manually discharge the battery down. Get it to about 3.3V
의
thanks for the reply.
Why is your explanation for why batteries last longer if stored cold and and partial charge?
의
Lithium batteries don't like full charge or discharge. There are some degradation mechanisms that are accelerated by running the battery to it's limits (close to 0% or 100%). So storing in the middle is best.
Cold temperatures slow down the chemical reactions in the batteries. BUT, you don't want to freeze the electrolyte (more damage / accelerated ageing, especially if you try to charge a frozen electrolyte), so "cold but not freezing" works best for storage.
의
Can you go into more detail or give sources describing the degredation mechanisms of Li-ion batteries from being fully charged and depleted?
Same question for the cold storage of batteries VS at room temp.
I am curious about the chemistry
의
댓글 달기
답변 2개
가장 유용한 답변
A battery activation board is the perfect solution for you, as it's intended to charge phone batteries. The only problem I've seen is that I wasn't able to locate one that works for the Pixel 6. This one says it's been tested with a Pixel 7 Pro, but no guarantee it'll work with a Pixel 6; that's the closest I came to finding one.
SUNSHINE SS-915 V9.0 Universal Battery Quick Charging Activation Board Test Fixture for iPhone for Android or IPhone 15/Pro/Max - AliExpress
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank you for this suggestion. I may buy it to try it out since its cheap :)
의
댓글 달기
1st - LI store best at 50-58% charge. Good batteries don't have much of a self discharge.
2nd some phones have a charge stop function at 80%, otherwise there is an app that might work on your phone.
I have used both on android.
3rd, I wouldn't waste money on extra parts. Tech is changing so fast it might be unusable in a couple years like the 3g phones were.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
thanks for the answer.
How do you charge a replacement phone battery without your phone?
의
댓글 달기
답변을 추가하세요
Han Hsuan Hsu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 192
