주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
''PS2''라고 알려진 이 기기는 2000년 3월 일본에서 Sony가 처음 출시한 6세대 게임기입니다. 미국에서는 같은 해 2000년에 SCPH-30000 모델로 출시되었습니다. 이 기기를 수리하려면 일반적인 도구만 있으면 되지만, 다소 까다로울 수 있습니다.
Issues with PS2 after replacing CMOS battery
Me and my brother recently opened up one of our old PS2s which is an SCPH-30003R. Before we replaced the CMOS battery, the disc drive was shooting out extremely fast, and it couldn't be closed, until we hit the reset button after which it worked and would read games.
Today we replaced the CMOS battery and all is well, it turns on fine and I can set the date and time, but the now the disc drive won't open at all and the blue light has no light at first, but upon pressing it it flashes for about 8-10 seconds before the light goes back off. The console otherwise has no other issues other than this.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
Yes that issue you are describing (the disc drive that is shooting out fast) is related to the CMOS battery. So replacing that should fix it.
The issue you are having now is related to something else. I don't think it's related to the top cover as the blue light won't turn on.
I would check the power/eject button ribbon cable to see if it's not damaged, it sound like it is. Otherwise replace this one. It's most likely the cable that has damage.
Can you let us know how that goes?
Thank you!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
duskmutt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 25
전체 시간: 232
