주요 콘텐츠로 건너뛰기
2012년 6월 출시 / Core i7 프로세서 Turbo Boost 포함 / 최대 1 GB DDR5 비디오 RAM
589 질문 전체 보기
Swapping harddrive for SSD in MacBook Pro 15 inch (2012).
Hey,
I am looking to swap the harddrive of a new 2012 MacBook pro 15 inch with an SSD and then replace the optical bay with the original
I was wondering if the process is exactly the same as previous models. I have looked at the tear down but wanted to make sure
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
Here's an article by OWC and bench results on the 15" standard: http://blog.macsales.com/14263-owc-ssds-...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I did this yesterday. I installed a Samsung 512GB SSD. The guide for the late 2011 model did match perfectly:
MacBook Pro 15" Unibody Late 2011 하드 드라이브 교체
And use this one for cloning the harddisk:
How to Install macOS High Sierra
Mac OS X 이미지
안내서
난이도:
쉬움
1 - 3 hours
MacBook Pro 15" Unibody Late 2011 하드 드라이브 이미지
안내서
난이도:
운영
25 - 40 minutes
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
hi,
I am planning to replace my existing HD with a new SSD. Im on OS X Lion 10.7.4
I need to clone my HD on to my SSD. Can I not do this using my latest Time Machine Back up?
wouldnt the TM back up install the OS plus all my applications and files etc ( basically bring it back to the current state including preferences)?
Is this what time machine is for?
thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Akshay,
If you opt to install by using a TM backup, all your data, applications and preferences. The only thing to account for is that the SSD needs to have the more space that what your TM backup uses.
댓글 달기
귀하의 답변을 추가하세요
jchu1990 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 38,365
