주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
What are the differences between iPhone 4/4s GSM/CDMA displays?
I noticed there are a couple similar questions here, but none answering quite what I'm looking for.
I've ended up with about 6 different display assemblies in my toolbox, and I didn't label them. How can I identify what models they go with? What are the differences between 4/4s displays, and GSM/CDMA displays? My goal here is to be able to tell these apart and label them, and also learn the differences for future reference.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 4개
가장 유용한 답변
anonymous 1577,here is a quote from this question "The connectors are the same for the digitizer and LCD and the screen will function properly between the models but the parts are physically different and will not fit either way." Read some more about it on here and here as well. As for the physical differences, just check the great guides for each model that you are inquiring about, take a look at the LCD's and you can actually see the difference. Good Luck.
Image one 4S and Image 2 iphone 4 GSM and CDMA with the CDMA on the left. Those images are from the ifixit guides, as you can see, lots of info about that.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thank you! I've determined that all of my displays are CDMA, and now I'm working on figuring out the 4/4s part. Thanks for your very detailed and helpful response!
The iPhone 4 GSM (ATT) is the easiest to recognize. Both of the top corner screw tabs are not in the corners.
댓글 달기
I've many a time had a customer tell me they had a 4 when it's a 4s. So I have managed to remove the bezel and glue the removed bezel to the new LCD. Also I'm sure the camera lense bracket is different too.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
So wait. i4 GSm, i4 CDMA, and i4S. Besides bezels, which screens and parts are interchangable and which aren't?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Can you use a screen and battery from CDMA ON A 4S
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
anonymous 1577 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 9
전체 시간: 15,346
