주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Does not shut down
When I shut down the laptop, it turns right back on as if I push the reset button instead.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
This sounds like a Windows issue, not a machine issue - check the logs for errors in Computer manager and see if you can find a matched log, otherwise recreate it and note when it occurred to trace it down - You want to look for an error like this:
이미지
To get to Computer management, right click on the start menu here, or search for it:
이미지
이미지
Look for these errors:
  • Kernel-Power (Event ID 41): Indicates the system rebooted without cleanly shutting down first.
  • Power-Troubleshooter: Shows what triggered the last wake-up or restart.
As soon as you have log files, come back and we'll see what we can find out. I have both the 640 and 645 (0=Intel, 5=AMD) and neither of mine have had an issue with this from a blank install from the MCT. These use modern sleep S0 (but it behaves mostly like S3 classic sleep), whereas the newer NPU 6/8 series (I only have a G1a, so can't speak on the G1i or G1q) are all in on modern S0. I forced it on my G1a unit in command prompt, but it was very much hidden on the Ryzen AI unit until I made it play nice with the powercfg CLI commands.
There are a few things you can try if the error cause is unclear:
Disable the Intel ME power management ("Allow the computer to turn off this device to save power"):
  1. Go to Device Manager.
  2. Find Intel(R) Management Engine Interface.
  3. Right-click Properties > Power Management.
  4. Uncheck "Allow the computer to turn off this device to save power".
Force S3 hibernate with CLI:
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
HelpMePlz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 28
전체 시간: 216
