주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Computer Entertainment에서 생산한 가정용 게임기입니다. PlayStation 4 Slim(CUH-2000 시리즈)은 기존 PS4의 더 얇아진 교체 모델입니다. 2016년 9월 7일에 발표되었습니다.
Error code su-42118-6 PS4
My PS4 Slim has random clicking noises at random intervals. My PS4 also cannot update at all and shows the error code "su-42118-6" whenever my PS4 is done updating. It might be a loose blu-ray cable/ribbon. This started after my PS4 refused to read disks.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
That error code is pointing towards the Playstation it’s blu-ray drive.
Could be the ribbon cable, power cable or the PCB.
First I would replace the ribbon cable and see what happens. This is most likely the issue here.
Still failing? Try to replace the power cable as well.
Clicking noise is usually the HDD. You can try a known working one as well and see what happens..
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
i have the same problem, i hear that the drive turning on and everything but still the error when i want to update my ps4. i just bought a ribbon cabel... if its not better than pcb. how can i know if its good or not?
의 공유
Yes, probably for the best to test with a new ribbon cable. Sometimes they do fail. If the error is still there, you might need to check the PCB. Do you also have ticking noises?
의 공유
댓글 달기
답변을 추가하세요
209 guy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 28
전체 시간: 201
