주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Envy x360은 2014년부터 HP에서 제조한 노트북 제품군입니다. 터치스크린과 완전히 회전하는 디스플레이를 특징으로 합니다.
Why does keep occurring even when saving videos
every time i attempt to save either images or videos and yet this happens why does it keep occurring what is the cause and the solution
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
The error code 0xA00F424F occurs because the Windows Camera app cannot find or access the
folder where it is supposed to save your photos and videos (typically the Camera Roll folder).
This is usually caused by the folder being accidentally deleted, moved, or having incorrect permission settings [1|new_window=true].
Solution 1: Manually Recreate the Camera Roll Folder
The most common fix is to ensure the expected folder exists in your user directory.
  1. Open File Explorer.
  2. Navigate to your Pictures folder (usually C:\Users\[YourUsername]\Pictures).
  3. Check if a folder named Camera Roll exists.
  4. If it is missing, right-click in the empty space, select New > Folder, and name it exactly Camera Roll [1|new_window=true].
  5. Restart the Camera app and try saving a photo.
Solution 2: Change Where New Content is Saved
If recreating the folder doesn't work, you may need to tell Windows where to save new files.
  1. Press the Windows Key and go to Settings > System > Storage.
  2. Click on Advanced storage settings (or "Change where new content is saved" on older versions).
  3. Look for New photos and videos will save to:.
  4. If it's set to a drive that isn't available (like an external drive you unplugged), change it back to This PC (C:) and click Apply.
Solution 3: Reset the Camera App
If the app configuration itself is corrupted, you can reset it to factory defaults.
  1. Go to Settings > Apps > Installed Apps (or Apps & Features).
  2. Find Camera in the list, click the three dots (or the app name), and select Advanced options.
  3. Scroll down and click Repair. If that doesn't work, click Reset [2|new_window=true].
Hardware Note for HP Envy x360
While this is primarily a software issue, if you continue to have trouble with your camera hardware (such as the indicator light not turning on), you can refer to the official maintenance guide for your device to ensure the internal module is seated correctly.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
my built in laptop camera won't save pictures, it gives me an error code 0xA00F424F<PhotoCaptureFileCreationFailed> how can I fix this problem
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Matt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 124
