주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2001년 10월 2일에 출시되었으며, 모델 번호 DVP-FX810으로 식별 가능함
It won't turn on.
I have checked the battery with multimeters, it's giving me like .1 Volt, which I don't think is very good. Also, the output which I am trying to check, was 1 volt earlier, but is now down back to .006 volts, which I'm not sure is right. Does anyone know what might be causing this? It won't turn on, even with the battery out.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
@narenvemury no matter what voltages you have showing right now, you know it's not enough. does not matter if it is 0.1V or .006V The variance i most likely caused by your meter but it's really only academic. You will need to try to charge your battery and see if it will hold a charge or replace it, which is most likely. Your battery sounds like it has been discharged below the threshold of taking a charge..
Now, your device should turn on if you use a 9.5V AC adapter, even with the bad battery. If it does not use troubleshooting flowchart from the Sony DVP FX810 SM.
이미지
P1 is the power fuse on the main board and D2 is the power diode on the main board as well.
You can download the SM from this page Sony DVP-FX810 under the Documents tab
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
It's true it has to work without battery!with the battery can try a charge at 19.5 V or even 24 continuous current for a short period of time .The polarity is, with the battery removed and looking at the pins side down towards you, left plus and right minus.There is a high chance that an electron excitation can be made and the voltage 3V.
의
댓글 달기
답변을 추가하세요
Naren Vemury 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 26
지난 30일: 48
전체 시간: 218
