주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년 11월에 출시된 PS5 콘솔은 크게 향상된 그래픽과 혁신적인 새로운 DualSense 컨트롤러를 특징으로 합니다. 미래지향적인 흑백 색상 조합은 기존 PlayStation 디자인에서 크게 벗어난 모습입니다.
PS5 LAN Disconnecting/Reconnecting Repeatedly
I’ve been experiencing an issue with my PS5 where the LAN (Ethernet) connection repeatedly disconnects and reconnects almost instantly. This happens back to back , mostly within the first hour of turning on the console and starting a game. Sometimes it temporarily stops, but then the issue returns.
I’ve already ruled out the Ethernet cable by testing with another one, and I’ve seen others report similar issues online without a clear solution.
Side note: my HDMI port is loose, and I have to angle the cable for a stable display connection. I’m wondering if there could be any relation between the two issues maybe heat, board stress, or internal damage affecting both ports.
Would it make sense to replace the HDMI port first and see if that resolves the LAN issue, or is this more likely related to the Ethernet port or its solder connections?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
I would bet its a heat-related situation. Especially if your console is fixed in the Vertical position, as this places the ether net port at the top edge - sitting directly above the ports where the internal fans vent excessive heat generated during gaming.
Had my PS5 since 2021, expanded my internal storage for an additional 2TB - and after 5 years, this bullshit starts happening? Conveniently enough, just in time for GTA6 to create enough hype that to cause a greed-driven inventory crisis (AGAIN !!!) for the 2nd time, since Covid - so the current scalp-rate has the cost of a PS5 Pro now fixed at the (currently) all-time-high price of $1,399 (a $100 increase from $1,299 - within the last 30 minutes...and apparently, this is the "last 1 available" - thanks, Amazon 🖕🖕🖕)
의
댓글 달기
답변 1개
가장 유용한 답변
Hi!
First of all, I don’t think it’s related to each other, BUT I would fix it anyway.
You either need to replace the HDMI port or maybe you can solder it in again for good.
Replacing the LAN port is also recommended. I’m afraid it’s the port it self. I would fix it at the same time and see how that goes!
Be aware, both jobs are difficult… maybe asking a repair shop would be a good thing to do.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Moose 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 18
지난 7일: 114
지난 30일: 491
전체 시간: 1,583
