Ram compatibility to upgrade ram
- Dose this model support 16 GB DDR4 2666Mhz ram
- Is it's motherboard capable for support 20 GB ram total
- As we it has 4 GB solded ram so my question is can I put 16 GB card in ram slot will support.
좋은 질문입니까?
좋은 질문입니까?
It might be limited to 12-20GB, which is typical for the partially soldered PCs :-(. A lot of them stop at 12GB, but there's been a few that have begun taking the full 20GB -- you'll need to check the specs and give it a try to see if it can do 20GB of RAM.
This is officially a 12GB machine though: https://psref.lenovo.com/syspool/Sys/PDF... -- you'll know if it works if it doesn't POST, throws weird errors or stops at 12GB with 20GB installed.
이 답변이 도움이 되었나요?
Yes, in many laptops with 4GB soldered RAM + 1 slot, you can install a 16GB DDR4 2666MHz stick, making total 20GB RAM (4+16)—if the motherboard supports it.
Some models officially list lower limits (like 12GB), but practically support 20GB.
Key points:
Match RAM type: DDR4 SODIMM, same or supported speed
System will run part in dual-channel, rest in single-channel
Always check your exact laptop model specs before buying
If your model supports it, yes—16GB + 4GB = 20GB will work.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 6
지난 30일: 26
전체 시간: 142
