주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
3세대 Sony PlayStation 5 DualSense 컨트롤러에 대한 수리 안내서, 분해 정보 및 문제해결 정보입니다. 모델 번호 CFI-ZCT1W 및 마더보드 모델 BDM-030으로 식별할 수 있습니다.
Faceplate Compatibility with other versions
Hi, I own a V3 Controller and it is the Spider-man 2 variant controller. It has developed stick drift and I am hoping to avoid having to solder anything.
Can I transfer the face plate and track pad plate onto a V5 controller?
If not, will the motherboard and sticks from a V5 fit and connect with internals from a V3?
For reference i have the motherboard serial number BDM-030. Any help is appreciated I would love to keep the livery on this controller if joystick replacement is the only option then that'll have to do. Thank you.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
Yes that is possible, but you do need the EXACT same model. Also the motherboard must match with each other.
It could be a little difficult, if you buy a incorrect model it just won’t fit as it should be.
Also another option would be to bring to a local repair shop and ask them to solder new hall effect sticks in.
Please let me know how it goes :)
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Hi! Apologies for the late response I just attempted it, and it did indeed work. I bought a brand new dual sense and was able to transfer all of the internal components apart from the touchpad which I wanted to retain and the new battery housing. All the internals from a new controller bolt up perfectly. I wanted to reuse the touchpad and faceplate so I did. Due to small changes in architecture I had to also reuse the old battery housing, rear plate and trim piece.
No problem at all! Glad that you got it solved :)! Thanks for sharing this with us! Have a great day!
댓글 달기
답변을 추가하세요
Thorne 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 16
전체 시간: 111
