주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2023년 9월 22일에 출시된 Apple의 최고급 플래그십 스마트폰인 iPhone 15 Pro Max의 수리, 분해 및 문제해결 정보입니다. 6.7형 ProMotion OLED 디스플레이, 새로운 5배 광학 줌 잠망경이 장착된 트리플 렌즈 후면 카메라 시스템, 5G가 특징입니다. iPhone 14 Pro Max의 후속 제품입니다.
Back Glass Replacement - Wireless Charging Coil Transfer?
I’m replacing the back glass on an iPhone 15 Pro Max. I was wondering if the wireless charging coil is something that I am able to transfer from the original? If so, is it just a heat and carefully separate situation? Or is this a component that will require soldering to fully transfer?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
The repair required the complete removal of the wireless charging connector and its associated components from the back panel. Following the connector (using heat and an ifixit pick), I slowly peeled the assembly away from the back glass. All in all the assembly includes the camera flash, the wireless charging coil (extremely delicate), and the connector. If it’s removed carefully and installed in the new part, you can avoid any need to run repair assistant and there won’t be the automatic record of the repair in your settings when you complete the process.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Did you review the iPhone 15 Pro Max 후면 유리 교체 guide the coil is part of the back glass the replacement will snap into the connector which you can see in Step17 ~ 19
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@danj thank you for your reply! Unfortunately, the repair I was performing was from the original unit to an aftermarket back panel. The repair required the complete removal of the wireless charging connector and its associated components from the back panel. Following the connector (using heat and an ifixit pick), I slowly peeled the assembly away from the back glass. All in all the assembly includes the camera flash, the wireless charging coil (extremely delicate), and the connector. If it’s removed carefully and installed in the new part, you can avoid any need to run repair assistant and there won’t be the automatic record of the repair in your settings when you complete the process.
의
댓글 달기
답변을 추가하세요
Luke Grimes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 8
지난 7일: 40
지난 30일: 128
전체 시간: 542
