주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo에서 Switch 2 시스템용으로 제작한 더욱 전통적인 방식의 무선 비디오 게임 컨트롤러입니다. 2025년 6월 5일에 출시되었습니다.
Can the switch pro 2 controller be repaired?
Unlike the original switch pro controller, the switch 2 pro controller doesn't have any apparent screws on its surface. Is it possible to open it to change the battery, or to replace joysticks should they fail?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
This question was migrated from https://www.ifixit.com/Answers.
의
This question was migrated from https://meta.ifixit.com/Answers.
의
댓글 달기
답변 1개
선택된 해법
Hi Miel!
Yes, you can replace the battery and joysticks. But the joysticks are most likely soldered on the motherboard (like the 1st one).
Most likely held by plastic clips first, when removed it should reveal the screws.
Did not received a broken Nintendo Switch Pro 2 controller yet, when I received one, will make some guides :). But this can take some time..
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
I found a teardown of the controller on by devJack on StackerNews. They're using a RKJX2 variant from Alps Alpine, which are designed very much like those in the JoyCons, that connect to the board using a ribbon cable.
So they're not soldered and should be "easily" replaceable, and I really stress that easily as it seems you need to remove the faceplate which is held on with plastic clips & adhesive to get to the screws to even take the controller apart. And it assumes the sticks are replaceable with off the shelf standard RKJX2 which has extra plastic near the cable side the variant in the controller doesn't have (hard to tell if this will impede anything from the pictures).
의
That is some great info!! That they are not soldered on means that the repair will be WAY easier. The only thing is that (as predicted) you need to remove the front plate. But again, this will not be that difficult.
의
for some reason, mine keeps going back in forth when i play a game, is that normal?
의
Try to calibrate the joysticks on the Switch. Can't you calibrate it? Then replace the joystick.
의
댓글 달기
답변을 추가하세요
miel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 54
지난 30일: 260
전체 시간: 1,133
