주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PS4 컨트롤러 모델 CUH-ZCT1. 소니 컴퓨터 엔터테인먼트에서 2013년 11월에 출시한 이 6축 3.7V 리튬 이온 배터리 컨트롤러 수리는 복잡하지 않습니다. (참고: 해체 안내서는 이 모델용이 아닙니다.)
Am I using this program correctly?
Hi so I finally got the analog sticks on my controller these are the Gulikit TMR Joysticks and I dont know whats going out with the right analog stick it clicks, but doesn't register and it looks like it drifts even though they supposed to be new. I tried in BF6 and I don't notice it since I have my dead zone set to 0. Can too much or little solder cause that malfunction?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개
Hi!
Can you set us pictures regarding the solder work?
기존 질문에 이미지 추가하기
Thanks!
Hi, I uploaded the photos it starts from the top going clockwise
Hi!
Thanks for the pictures! The pads do look damaged in the 2nd and 3rd photos. Can you remove the solder there and sent a photo again? Is that possible? Thanks!
I will do it as soon as I can
Hi, I uploaded the removed solder from the 2nd photo I did noticed the exposed copper
댓글 달기
답변 1개
선택된 해법
Hi!
It does look like that the pads are damaged, causing this issue.
I’m afraid you need to repair the pads first.
Here is some explanation: https://youtu.be/dtZl7cLYc40?is=0ieMGMQp...
Please let me know how that goes!
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thank you I'll just a new MB and analog sticks it always something with this and its getting tiresome
I understand yes, I would swap it out for a new motherboard as well. Please let us know how that goes! Thanks!
댓글 달기
답변을 추가하세요
Christopher D 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 20
전체 시간: 118
