주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Turtle Beach Stealth Pro는 Turtle Beach에서 2022년에 출시한 무선 게이밍 헤드셋입니다.
My microphone stopped working
The issue is the microphone stops working. Prior to it stopping, it would work at half-mast. It is a design flaw. Apparently, the wires that connect to the microphone come loose. It is caused by moving the microphone boom up and down. I can't find anything on how to break it down to access the wiring. Any help is greatly appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi!
I looked around a little and could not find a disassembly guide for the microphone for this model. Based on what I could see the microphone looks like it is molded in place, which would make it almost impossible to open without permanently damage the microphone.
Otherwise, the general rule would be to look for any seems and try to jam something into those seams.
In the image bellow I've marked the two seams I could see, if the microphone is damaged anyway (and you cannot RMA the microphone) you could always try breaking open those seams to see if it is doable without totally mangling the microphone (and upload some pictures of it here or in a guide)
이미지
I can also include this link to an exhaustive list of troubleshooting steps for general Turtle Beach headphones that could be tried before breaking the microphone.
Good luck,
Cheers
Update: 2026-04-28
I see, well then here comes some more info.
In general, taking apart a headset is quite easy.
  • You take off the earpad, which typically exposes screws some screws.
  • And undoing those screws gives you access to the internals of the headset.
  • In your left earcup you will have a battery, so be a little careful.
  • Also note, the Stealth earcups are on top of being screwed, they're also glued. The screws should be sufficed to keep everything together once you're done.
Looking around, I only found this Teardown of the right side (but the process is the same for either cup):
However, for some clearer instructions I would look at the first 6 steps in this guide for a similar headset with the same earpad snapping mechanism. Note, do not do step 7 and forward as that does not apply to your issue.
If you prefer video instructions, you could check out this video guide on Youtube, however their headset does not have the snapping earpads as your headset will.
If you want further help with the wiring for the microphone, edit and update your answer with images, see guide for 기존 질문에 이미지 추가하기.
Good luck,
Cheers
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
매우 쉬움
2 - 5 minutes
Turtle Beach Elite Pro 왼쪽 스피커 이미지
안내서
Turtle Beach Elite Pro 왼쪽 스피커 교체
난이도:
조정
30 minutes
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I truly appreciate your response. The problem is actually not the microphone itself. It is the base of the headphone. Where the microphone meets the base itself, apparently moving the microphone up and down causes the internal wires to become disconnected. The microphone itself has been replaced with a new one. Thank you for taking the time to answer.
의
@mariaolver92486, I've updated the answer with some more information for you :)
의
댓글 달기
If you haven't figured out how to break it down. Pull ear pad off take the 4 screw out pop out of speaker housing then there is 4 more screws that hold plastic cover to the microphone board. The housing is siliconed in to place . I was unsuccessful fixing my microphone as there was no lose wiring . I think the jack itself gave out. As it worked for 2 months at half mast ..
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Maria Olvera 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 47
지난 30일: 119
전체 시간: 693
