주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PS4 컨트롤러 모델 CUH-ZCT1. 소니 컴퓨터 엔터테인먼트에서 2013년 11월에 출시한 이 6축 3.7V 리튬 이온 배터리 컨트롤러 수리는 복잡하지 않습니다. (참고: 해체 안내서는 이 모델용이 아닙니다.)
Will this cause any issues?
My impatience will the end of me I noticed a scratch on the top of the board will this cause me issues?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I'd say not; that appears to just be a scratch on the protective solder mask coating. It doesn't look to me that the underlying copper trace is damaged to any real extent, and even if it's scratched through, you're looking at a large ground plane that has more than enough electrical continuity that it wouldn't matter.
If you wanted to be paranoid about it, you could buy a tube of liquid UV-cured solder mask and cover the scratch, but unless your controller is exposed to a corrosive atmosphere, there's little chance it's going to cause you any problems. Otherwise you could always coat it with some non-conductive sealant like epoxy, silicone sealant, or even hot glue. Or a strip of electrical tape would keep it from shorting if there's anything close to it that could make contact.
Long story short, you should be okay.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Christopher D 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 20
전체 시간: 65
