주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony PlayStation 5 DualShock 시리즈의 후속작인 4세대 Sony PlayStation 5 DualSense 컨트롤러에 대한 수리 안내서, 분해 정보, 문제해결 가이드입니다. 모델 번호 CFI-ZCT1W와 마더보드 모델 BDM-040으로 식별할 수 있습니다.
What the problem with my x button
이미지
이미지
이미지
이미지
이미지
이미지
So the problem is that I was given a PS5 controller, but when I turned it on, the X button didn’t work, so I couldn’t log into any account. I opened the controller and did some cleaning I found online, but even after that it still didn’t work. I even removed the rubber piece from the PS button and tried to make contact with the X button membrane, but it still didn’t work.
I know it’s not a problem with the rubber because I used the same PS button rubber and touched the circle button membrane, and on the PS5 the controller registered a back action. That’s why I’m asking, because I don’t know if it’s a circuit issue or something with the pins, and I also don’t know how to fix it. I imagine it would require soldering, and I’m not very good at that and don’t have the right tools.
Whoever can help me, I would really appreciate it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi!
In this case, I would replace the button circuit membrane.
You don’t need to solder for this.
Before you replace it, make sure you got the exact same model as the one that came out.
If you need guides, please let me know!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jahdread Manso 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 17
전체 시간: 233
