주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Tahoe 리미티드 에디션을 제외하고, 이 차량은 2000년형 모델을 위해 새로운 GMT800 플랫폼에서 재설계되었으며, 풀사이즈 픽업트럭 및 SUV와 플랫폼을 공유했습니다.
map sensor whats its function
Sometimes when driving my Yukon it starts to hiccup and bog down as if it's trying to stall. Occasionally it might just cough more and not stall. What's going on? I changed the mass air flow sensor; are there any other sensors I should look at?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
What are the conditions of the following components:
Air filter, spark plugs, spark plug wires, oxygen sensor(s)
It seems like the problem is definitely in the induction, combustion, or exhaust, but a check engine light usually points to what exactly. Are you throwing any codes?
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I agree with David - checking the computer memory is always the first step at diagnosing any computer controlled vehicle. Any stored code will help guide in further diagnosis. Some parts stores (like Autozone) will check the computer memory for free. You can also buy software and cable kits that will allow you to use a laptop computer as a scan tool. Here is the one I have: cable No, I am not affiliated with this in any way.
The software also allows you to read sensor inputs which can help diagnose intermittent problems. Trying to nail down an intermittent problem can be quite frustrating, even for the best mechanics.
Hope this helps,
BILL
이 답변이 도움이 되었나요?
점수 2
댓글 달기
i have a chev or gmc engine block need to know the size an year the block#19W441749 V0307 D or 19W441749 V0307LD
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
glen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 21
전체 시간: 2,170
