주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Numatic에서 제조한 Henry 진공청소기입니다.
Power cut and not working
Not working. Power cut
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Like @rodolfomeave, I'm not familiar with your particular vacuum, but I had the same issue with a Harbor Freight shop vac.
By testing the power going to the fan motor, I finally isolated it to a failed thermal fuse on one of the motor leads. These are designed to blow when the temperature exceeds a particular limit, but I have no reason to think mine was anywhere near that range when it blew. Anyway, replacing the fuse got the vacuum up and running again and I haven't had an issue with it since. Here's the part I purchased; yours will probably look similar, although you'll need to use the markings on it to determine what value to use for a replacement.
10pcs 10A 250V TF thermal protection Rice cooker fuse RY-65 75 80 100 120 175 185 210 230 280 Metal shell Temperature Fuse - AliExpress 502
이미지
Good luck, and be sure to come back and let us know what you find!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I do not have a Henry Vacuum, but if you are still having power issues there are some troubleshooting checks that you can do:
  • Make sure power cord is fully connected to power outlet
    • If outlet is a GFCI, also known as GFI, outlet; Make sure the breaker is not disconnected
  • Inspect power cord for any hard kinks, cuts, or anything that could potentially have broken the copper wire inside
  • Inspect for broken or loose power switch
  • Inspect internal wiring and PCB for broken connection, burnt components
Hopefully this helps!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Bob 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 23
전체 시간: 204
