How to Install SSD
I want to install a SSD into my MacBook Pro 17. I bought a Mercury Electra 3G SSD. How do I install it into my MacBook Pro? It didn't come with directions, although they told me it would work.
좋은 질문 입니까?
좋은 질문 입니까?
I just installed a second hard drive in the place of the optical drive in my MacBook the other day! It's pretty nice having the extra capacity.
Even if you just replace your current hard drive with your SSD, you'll see a significant speedup.
Here are the relevant guides:
Replacing the current hard drive:
MacBook Pro 17" Unibody Hard Drive Replacement
Removing the optical drive:
MacBook Pro 17" Unibody Optical Drive Replacement
Go to the last page of this guide on replacing the optical drive (it's for my machine, but the last page would help for installing the second drive)
Installing MacBook Core 2 Duo Dual Hard Drive
And finally, the part that iFixit sells for the second hard drive:
Good luck and enjoy your SSD!
상품
$24.99
안내서
난이도:
운영
15 - 30 minutes
안내서
난이도:
운영
1 - 2 hours
안내서
난이도:
운영
1 - 2 hours
해당 답변은 도움이 되었습니까?
You either have to: 1.) replace your current HDD with the SSD or 2.) remove the SuperDrive CD burner and replace with your current HDD and put the SSD in the original place that the HDD was in. The latter is the most popular because you can still use the SuperDrive via USB by purchasing external case for the SuperDrive and you just plug and play with the USB, therefore having a HDD and SSD. Also, with the latter, you must purchase an OptiBay expansion kit to be able to place the HDD into the SuperDrive bay.
해당 답변은 도움이 되었습니까?
24 시간 전: 4
7일 전: 6
30일 전: 11
전체 시간: 25,589
