주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
소니 PlayStation 5 DualSense 컨트롤러 5세대 모델의 수리 안내서, 분해 정보, 문제해결 정보를 다룹니다. 모델 번호 CFI-ZCT1W와 마더보드 모델 BDM-050으로 식별할 수 있습니다.
Need Help identifying and looking for replacement part
이미지
Hello! this controller was my first attempt at repairing and i accidently touched the plastic socket with the soldering iron. im trying to find the name of the socket on the controller that the trigger ribbon inserts into. i can't tell if it's the same as the microphone socket. Below is a link to aliexpress with a similar looking part to it but just in white and wondering if i can just use that. Thank you in advance!
https://www.aliexpress.us/item/325680918...
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
Yes you can use the white one. Color doesn’t matter. The 16 pin one is the one you need.
But first, count the pins on the controller, just to be sure if it really is 16 pin!! Confirm it first.
Also, you can contact the seller and ask for which revisions they are meant.
In short: most likely you need the 16 pin yeah.
Please let us know how it goes!
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Hello! Thanks for responding! Counted the pins and it seems be a 6 pin. Guess V5, Motherboard Model BDM-050M uses a the smaller version instead of the 16 pin. the Part will take some time to arrive. Hopefully it all goes well and i remember to report back. Have a great day!
Ah sorry! The V5 is indeed using smaller ones. Hopefully it will arrive soon, so that you can repair it :). Have a great day as well!
댓글 달기
답변을 추가하세요
Omar G 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 12
전체 시간: 169
