주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년 4월에 발표 및 출시된 2세대 iPhone SE의 수리 및 분해 정보입니다.
iPhone se 2020 problem touch id
iPhone SE 2020. Home button works normally, but Touch ID does not respond at all when adding a fingerprint. No error message appears. The phone was opened previously for network repair. Hidden Apps are asking for Touch ID and never fall back to passcode. Has anyone seen this before?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
If the Home button still clicks and functions normally but Touch ID doesn't detect your finger at all, that usually points to a communication issue with the Touch ID sensor rather than the button itself.
Since the phone was previously opened for a network repair, it's worth checking the Home button flex cable and connector for damage or poor contact. A board-level issue is also possible if the repair affected the Touch ID data lines.
I'd also check for any panic logs and run an iPhone panic log analysis. While Touch ID issues don't always generate panic logs, they can sometimes reveal hardware communication errors that help narrow down the cause.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
DJAMAL YACINE 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 25
전체 시간: 113
