주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014-2019 Toyota Highlander, 3세대 중형 SUV.
fuel door won't open
Fuel filler door won't open
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi @gregheard
There's a relay that is operated by the fuel door switch to operate the fuel door lock motor.
Check if you can hear it operating when you operate the fuel door switch
Unfortunately I can't find where it's located as it's not mentioned in any of the instrument fuse panel fuse block diagrams I've looked at.
It may be behind the fuse block as looking at the wiring diagram for the 2016 model (it's the same cct for 2014-2019) it is in the same location as the fuses for the fuel door.
이미지
(click on image)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
what have u checked? It is electrically operated, so start with the fuses. Past that, it requires wiring and chassis diagrams to be able to trace the wires and get at the solenoid ******that releases the latch.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thanks, Bill I had already checked the fuses and they are good
댓글 달기
답변을 추가하세요
Greg Heard 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 23
전체 시간: 139
