주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toyota RAV4는 완전히 새로운 플랫폼을 기반으로 2006년형 모델로 재설계되었으며, 2005년 프랑크푸르트 모터쇼에서 처음 공개되었습니다.
Transmission drain and fill
I have a 2011 Rav4, 2-wheel drive. The owners manual states that I should drain and refill my transmission? Others have told me no. Thoughts?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
If the owners manual indicates it should be replaced, the reason is that the fluid wears out. It no longer lubericates well and it carries ultra fine metal as the gears wear. You will observe this in the darkness of the oil when you drain it.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I have to agree with Michael; the owners manual is written by the manufacturer, and who would know better than the people who built the car? I'd go with their recommendation.
의
댓글 달기
This would best be done at a reputable repair shop. You dot have th proper tools and facility to do this. You would need a filter kit for this procedure.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
John, you're making assumptions. How do you know Alan doesn't have the tools or space? I've replaced engines in my driveway; I see no reason why a transmission can't be drained and refilled by the owner given a basic set of tools. And yes, that would even include replacing the filter if appropriate.
After all, that's the whole point of this site - to enable people to do their own repairs rather than paying someone else.
의
댓글 달기
답변을 추가하세요
Alan Hoffman 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 36
전체 시간: 95
