주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL 760NC로도 알려진 JBL Tune 760NC 헤드폰은 맑은 사운드를 제공하는 액티브 노이즈 캔슬링 기술이 탑재된 무선 헤드폰입니다. 가볍고 접을 수 있어 장시간 음악 감상에 최적화되어 있습니다.
Why its Microphone not working
I can hear through my headphones, but my microphone isn't working, so I can't input sound. I'm only receiving audio output, with no microphone functionality.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
This can be caused by multiple issues.
First of, make sure that your microphone volume, or call microphone volume, on your device is neither muted or set too low, if you have such settings available. Also check that the app you're trying to use the headset with has sufficient permissions for microphone, Bluetooth and the like.
Otherwise, make sure you have sufficient Bluetooth device permissions for your headset. How to check this differs per device, but can typically be found by:
  • Entering Bluetooth devices / Paired devices menu.
  • Find and select the headset (or press more info).
  • Then check if you have allowed any available options, and do allow any and all options available, such as Phone calls, Media Audio, Contact Sharing, e.t.c.
Else, try to unpair or "forget" the headset, then re-pair the headset.
Make sure you're having the latest firmware / devices drivers.
Is there a companion app? If there is, check around in the settings for microphone settings or anything of the like.
Try out the headset on another device to discern if it is the microphones/headset that is broken, or if it is a software issue.
Another common technique is to fully discharge the headset (typically by using it until it turns off), and then charging it back to full battery again.
All these tips above are assuming that the microphones works. Have you recently dropped the headset, or gotten it drenched in water? Please respond and we'll see how we can assist you further.
Good luck,
Cheers
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Nitin verma 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 26
지난 30일: 121
전체 시간: 318
