주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
디스크 공간이 부족하신가요? 백업 솔루션이 필요하신가요? 외장 드라이브는 사무실이나 이동 중에 사용할 수 있는 추가 스토리지를 제공합니다. 여기서 수리 방법을 알아보세요.
Disassembly of Simple Drive Deluxe
I have a REALLY old SimpleTech Simple Drive Deluxe, and it has stopped being accessible so I'd like to remove the drive from the case (I have a number of adapters for different types of drives) and see if I can still access the data. The drive has 4 deeply-inset screws that appear to be Phillips-head. I just bought an iFixit Essential Electronics toolkit and the largest Phillips head seems to fit (loosened up 2 of the 4 screws) - but I cannot get it to "catch" on the other two.
Any tips?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
If two screws loosened but the other two won't catch, double check that they're actually Phillips screws and not Torx or a security variant, as older external drives sometimes use different screw types in the same enclosure. Try applying firm downward pressure with the correct sized bit and inspect the screw heads with a flashlight. If the drive itself is still healthy, removing it from the enclosure and connecting it through a compatible adapter is often the easiest way to recover the data.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Cara 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 29
전체 시간: 74
