주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
atf fluid level check
some sources say to check atf fluid
when car is level and fluid is at 185°
to 203°. Unable to reach that temperature except mountain driving 500 miles away. some say engine operating temperature.
car is 2019 buick envision 2.5L with
6 speed trans. also does level mean
as car sits on level surface or as car frame sits on a lift. thank you
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Here's the repair manual page specifying the transmission fluid level check procedure.
Transmission Fluid Level and Condition Check — 2019 Buick Envision Base Service Manual ~ LEMON Manuals
From the manual:
Driving in second gear will cause the transmission to spin faster, generating more heat and raising the fluid temperature. I don't know if your car is equipped, but the manual says you can check the temperature using the Driver Information Center.
A tool like the Torque app connected to an ELM327 dongle will let you read the temperature with the car running if your DIC doesn't show it (or you don't have a DIC).
As far as being level, there isn't enough difference between sitting on level ground and sitting on a lift to matter; the frame should be level in either case unless you've done something like put oversize tires on the rear or a weird situation like that.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
gerald beauchamp 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 23
지난 30일: 63
전체 시간: 204
