주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TECNO Spark Go 2 Android 스마트폰(모델명 TECNO KM4)에 대한 수리, 분해 및 문제해결 정보입니다.
back Camera error , wont work
why is my back camera won't work whenever i try to switch it say on the screen . camera error
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
If there's not any reason for the physical cameras to be messed up (water, heat, or impacts, to name some), I would look for any settings that might disable specifically the back camera, for some reason:
  • Firstly, swipe down into your Quick Settings (notifications area), look if there's a button for "Camera Access", make sure it's on, or that any other option like that in there isn't blocking your camera.
  • If you've manually gone through enabling Developer Options, follow the rest of this portion. Make sure "Sensors Off" isn't enabled, which can be seen as a button in your Quick Settings if you've changed it to be pinned there. If you have gone through Developer Options but never pinned that function, find one of the menus in there along the lines of "QS Developer Tiles" and see if that same "Sensors Off" option is enabled there.
There could also be an issue with the camera app. If it doesn't work in other camera apps either, then it isn't likely just that app.
Otherwise, it may be damaged or malfunctioning. If you know there wasn't an accident with the phone that could've caused that, make sure any previous owner of the phone didn't experience an accident with it. Sometimes, an accident that happened a while ago can result in issues that appear down the line.
If you got the phone from a carrier, a store, or TECHNO itself, you might need to see if you have any warranty on the device, or you could contact TECHNO. Before you do any of that, though, double check that your phone doesn't have any software updates. It may've been a faulty update.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
illya mclaine 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 68
전체 시간: 231
