주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 3월에 출시된 Apple의 11" MacBook Air 업데이트 모델은 5세대 Intel Core i5 및 i7 프로세서를 탑재하여 성능과 배터리 사용 시간이 소폭 향상되었습니다.
No Internal or External Display Issue
Have a 2015 A1465 here (820-00164) that chimes / boots but there is no display at all. We have tested with another known display assembly & on external displays but still nothing. From what we can see we are getting readings from the outputs, but nothing, just a black un lit screen. GPU failure I thought gets a white screen. The fan is also at high speed. What can be? (I do believe that the technician has replaced the SMC 2x already).
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
Does the system respond when you use the system in Clam Shell mode you do need external keyboard and mouse here besides the external display connection. The lid must be down as the Hall sensor needs to see the lid is closed to enable the external as the primary display.
의
@danj Will try it. And update as and when.
의
Unite is dead, green light only, no fan spin, zero..... donor unit.
의
댓글 달기
답변 2개
Try connecting it to an external monitor but with the lvds cable disconnected
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@nik_one - Disconnecting the LVDS cable won't change anything here from a diagnostic sense. If the LVDS connection was corroded up then I could see that resolving a possible short.
Putting the system into Clam Shell Mode would be easier and offer a useful data point.
의
댓글 달기
If you can get the external display to respond then you should be Ave to identify the system issue going into CPU Safe Mode. If you can't get into Clam Shell mode that points to a CPU module issue where the I/O chip part has failed.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
livfe 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 11
전체 시간: 100
