주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Black And Decker 무선 전동 잔디깎이 CM1836은 36V 통합 배터리를 탑재한 18인치, 64파운드(약 29kg) 무게의 모델입니다. 세 가지 잔디깎기 모드(후방 수거, 멀칭, 배출)를 제공하며, 잔디깎기 높이는 1.5에서 3.5인치(약 3.8~8.9cm) 사이로 조절할 수 있습니다.
How do you get a replacement battery same size
How to get a replacement battery
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
The part number is 90550289SV but I don't kno where you would buy it.
의
@alberteinst6187 According to parts diagrams from this link, https://www.ereplacementparts.com/models..., the drawing shows three batteries. My guess is if you measure each battery for H x L x W, the dimensions should match available lead acid batteries I showed, below. While the battery pack is discontinued, it's just a matter of determining if a) a three pack of original batteries make up a 36vdc battery pack, are 2) batteries with the same dimensions that are available anywhere online, Home Depot, Lowes, Target, etc, then 3) buying three and transferring the wire connectors from the original pack to the new ones. Wired in series; positive terminal of battery-1 to negative of battery-2, positive of battery-2 to negative of battery-3. This leaves the negative of battery-1 and positive of battery-3 to connect to the mower.
의
댓글 달기
답변 1개
선택된 해법
If your battery pack is made up of three 12v batteries, you can buy them from Home Depot or online from many battery distributors. The basic 12v sealed AGM battery is rated for 7 amp hour. There are many applications for this battery; home alarm backup power, Verizon Fios battery backup for Verizon phone line coupled to its fiber optic system, hobby power for radio control engine starters before electric power took over, etc. Examine labeling on your battery pack for specs. AGM is more expensive than conventional sealed gel cell batteries and probably hold up better to high current demands of electric lawn mowers.
이미지
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Errol Rodrigues 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 31
전체 시간: 78
