주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi Redmi 9C는 2020년 6월에 출시된 Xiaomi의 보급형 스마트폰입니다. 6.53인치 IPS LCD 디스플레이, 13MP 후면 카메라, 5000mAh 배터리를 탑재했으며 Helio G35로 구동됩니다.
How to replace mobile screen
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
It's fairly straight-forward on your phone, much the same as it is for a lot of Android phones. First thing is to take off the back panel, then unscrew the midframe retaining plates on the top and bottom. Disconnect the battery first, then the display connector from the motherboard and the lower connector on the daughter card. Separate the LCD from the midframe and remove it. Clean the old adhesive, glue on a new display with something like B7000 and reassemble. This video shows you the whole process.
Redmi 9c Lcd Screen Replacement Without Frame - YouTube
As you work, take lots of pictures and once you're done, you can use them to create your own iFixit guide to that repair. It's easy, fun, and will have the appreciation of the repair community, especially those who come after you with the same problem.
Create a new Guide - iFixit
Good luck, and let us know how it all turns out!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Tiwana Tiwana 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 16
전체 시간: 76
