이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개:
@testemail what makes you think that you have an issue with your ABS unit? Have you got your vehicle scanned? Any error codes? What are the issues with you brakes? What exact year is your 300?
In addition to oldturkey03's question, if the abs indicator turned on and remained on, there's an error code but decoded by readers/scantools Autozone, Advanced Auto, transmission, collision and repair shops have. Not generic low cost readers. If the abs indicator cycles on and off with other indicators when turning on ignition, abs is operating correctly (power on self tests including all wiring to wheel speed sensors). Abs errors are usually C type codes.
oldturkey03 의 공유
F Dryer 의 공유
