주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2022년 09월 16일에 발표된 Apple의 "작아진" 플래그십 스마트폰은 6.1인치 ProMotion OLED, 트리플 렌즈 후면 카메라, 5G 이동통신이 특징이며 새로 설계한 "Dynamic Island"를 전면 카메라와 상단 센서 주위에 배치했습니다. iPhone 13 Pro의 후속작.
Cellular RF front and scan test
I did a complete housing swap, and when I transferred over the charging dock flex connector the barometer must've been damaged by the alcohol as the diagnostic tool flagged the barometer and it was having a kernel panic. I've gotten a new charging port and it seems to be working fine, no panic. I did a diagnostics test and everything came back fine other than the cellular RF. what is this issue? Is there anything I need to check as far as connections?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Cellular issues can be very difficult to pin down because so many components are involved. But based on the fact that you did a housing swap, this is likely an antenna somewhere. This could also be an issue with the new charging port flex cable, as there are some antenna components on that assembly. But, honestly there are antennae everywhere. What happens if you put the old charge port flex back? Or at least connect it back to the board?
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
Thanks for the reply. I got another OEM pull charge flex and its working as far as all the testable components but still giving the cellular RF issue. it picks up 1 bar cellular occasionally then drops to SOS or no service. When it did pickup service, it was able to send a text and call, but data was hung up, not sure if that narrows it down any. Any tips or suggestions would be appreciated. Im already in the hole on this phone. The housing frame is a premium part 3rd party from MobileSentrix.
의 공유
So i was using a verizon ESIM and it was picking up the 1 bar and no data, but I swithed it to ATT sim and its getting full signal and speeds of 396mbps on 5G but still giving the Cellular RF flag in the diagnostics.
의 공유
What should I do? If that’s safe to update? I want to update iOS 27 What’s gonna happen?
의 공유
댓글 달기
답변을 추가하세요
CAB 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 11
지난 7일: 65
지난 30일: 286
전체 시간: 902
