주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년 9월 18일에 출시된 Apple의 6세대 스마트워치로, 셀룰러 연결 기능을 선택할 수 있습니다. 모델 A2376, 44 mm.
Reattaching screen after battery replacement
I just replaced the battery in my Apple Watch 44mm Series 6. The battery replacement went fine but I am struggling to reattach the screen. I purchased the Screen Adhesive along with my new battery but the adhesive I received was worthless - I didn't stick anywhere. I tried using E6000, which the repair guide recommended as an alternative but it doesn't feel as though the screen is securely attached. Does the screen snap in at all, or is it just the tape/glue that holds it in place? Any recommendations for securely reattaching the screen will be appreciated.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hello,
It is only the adhesives that hold the screen in place. If you don't adhesive the screen down a lot, then the screen will come off, and you will loose all of your water resistance.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Thank you. I'll try again.
의 공유
@jimstone You'll need to apply pressure after the screen is adhered on otherwise the bond would not be strong enough and it'll fall off after a few days(I learnt the hard way)
의 공유
Thanks. It is sitting with a spring clamp on it right now!
의 공유
댓글 달기
답변을 추가하세요
James Stone 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 57
전체 시간: 146
