주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
주요 제조사의 완제품이 아닌, 시중에서 구매할 수 있는 DIY 부품으로 조립한 데스크톱 PC입니다. 시스템 통합 업체에서 시중 부품을 사용하여 조립할 수도 있습니다.
Computer shuts off when launching game
So my Buddies PC turns off when launching a game, he has brought it to two different repair shops (one of the shops replaced the PSU), It worked perfectly fine with them. I brought it home works perfectly fine for me. When he brought it back to his house though it started again, multiple different outlets, different PSU cords, nothing works. No one knows what is causing it. we have narrowed it down to all his power outlets being faulty, but his GF's PC doesn't do it. He hasn't been able to play games in months, we are defeated.
Any suggestions will help.
Specs:
-Ryzen 7 7800X3D
-Gigabyte Wind force RTX 4070
-Corsair 32GB DDR5 6000mhz
-Asus B650 PRO RS WIFI
-Idk what brand 800W Gold series
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Try your friend's pc in your home/apartment to verify the pc works with the game program. If the pc runs correctly, your friend's power outlets may be faulty or something more serious. If you know how to use a multimeter, measure outlet voltage. It should be 110-120 vac. Compare your outlet voltages with his.
의 공유
댓글 달기
답변 2개
가장 유용한 답변
Thank you, idk what happened but I tried plugging a new keyboard and mouse into his PC, and it worked. Idk if the USB was shorting something out or what, but it worked.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Hello,
Now here's what I think that's happening here: Your setup is over-wattage, causing the whole computer to switch off in order to make sure that nothing blows up. Did you so happen to upgrade the PSU by any chance if and when you were upgrading your PC? If not, then that would've been my very first step.
Hope this helps,
T
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Shay Major 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 25
전체 시간: 96
