주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Skullcandy Air Raid는 2013년 11월 15일에 출시된 무선 휴대용 블루투스 스피커로, 블루투스가 지원되는 모든 기기에서 음악을 스트리밍할 수 있습니다.
Rained on while charging
I was charging it outside and it rained lightly for maybe 30 minutes or so and now the speaker won't turn on at all how can I fix itI was charging it outside and it rained lightly for maybe 30 minutes or so and now the speaker won't turn on at all how can I fix it
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Rain can short circuit electronics, starting with water entry into the charging port. Whether this caused the battery to drain is one possible issue. Disassembly should be performed to wipe off remaining water, allow inspection of wiring for corrosion and damage to electronics. Tissues, cotton swabs and isopropyl alcohol can help with clean up. If you are successful in disassembly, leave parts exposed to dry out. Placed in a tray on top of a gas stove with its pilot light supplying gentle heat, in a gas oven with similar pilot light for heat or out in the sun. Warmth over several hours will help evaporate remaining moisture. Reassemble and try recharging. The battery may recharge and allow operation. Battery specs are printed on labeling. Click on the Guides tab in the upper right to open a new page and click on Battery Replacement to reveal disassembly procedures or below. Skullcandy Air Raid 배터리 교체. Hopefully, damage didn't occur, the battery recharges, and you restored your Skullcandy Air Raid back to full function.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Carlos Cordova 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 33
전체 시간: 88
