주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년에 출시된 Dell 7000 시리즈 모델로, 10세대 Intel 프로세서와 4K 디스플레이 옵션, 더 작고 견고한 알루미늄 바디를 갖춘 14형 노트북입니다.
Keyboard typing extra adjacent letters
I have a Dell Latitude with an i7-10610U. The built-in keyboard suddenly started typing extra adjacent letters. For example, when I press Q, it types QA.
The issue affects multiple keys, while the number keys seem to work normally.
I tested with an external USB keyboard, and it works perfectly with no extra letters or typing issues.
Since the issue is with the built-in keyboard, I want to try fixing it myself before replacing the entire keyboard, since a replacement is quite expensive.
What could be causing this type of hardware failure, and what can I try to repair or clean first? Is there a way to fix the affected keyboard circuits/membrane or ribbon connection without replacing the whole keyboard? Thank you
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hello,
You could just try to clean the keycaps, as dirt, dust, and debris could have an effect when typing keys. Otherwise, it isn't that worth it to repair singular keys, in which you should probably just replace the whole keyboard.
Good luck,
T
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Shechinah Belle Valenzuela 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 33
전체 시간: 95
