주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Currently lost of power
No power I don't know what happen it directly lost power since my last used
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
@jundeewong Do you mean that the toaster itself doesn't have power, or does your whole house not have power? If your toaster does not have any power, then I suggest opening it up and changing out the PSU or power cord. If your whole house does not have power, then I would suggest that you either wait for the electricians to bring the grid back up, or change the fuses if the fuses for your home has blown.
의 공유
댓글 달기
답변 1개
If you didn't check you outlet ckt breaker, then my assumption would be, u can't fix it if I told you what the problem was.
However, assuming the breaker is tripped, then the issue might be a bad middle door switch or a worn mechanism.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jun Dee Wong 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 31
전체 시간: 101
