주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G502 Lightspeed 무선 게이밍 헤드셋의 수리 및 분해 정보입니다.
Why it cannot charge properly?
Why it won't charge properly? It keeps connect and disconnecting many time.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
If yours is covered under a 2yr warranty, Logitech should honor repairs free of charge. This presumes the charging adapter, connector and headphone connector aren't damaged. Outside of warranty; try using the Guide tab to disassemble yours if the battery is worn out.
의 공유
I think I have a similar issue. I didn't get the warranty because I assumed out of the box it would work fine. Not only does it have charging issues, but it also has issues working properly when plugged in. I have tested the USB cable, tried different USB cables, and different computers, and I am 90% sure it is the headset itself that is the issue. I have disassembled it, but I don't see any visible issue, and continuity seems good for the USB-C port. At a loss here; if you have a suggestion besides sending it back, I am all ears
의 공유
@qwaddles if it is new, it should have a logitech warranty. If it is used or refurb, then you will have to find service info - maybe on youtube and troubleshoot/fix it or ask Logitech for service center repair.
의 공유
댓글 달기
답변 1개
the charger cant supply enough current or the headphone it drawing more current than it is suppose to.
Sub a good charger or try ur chgr on a diff headset. - it could also be the cable.
If it is the headset, it will have to come apart and determine if it is a replaceable part that will fix it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Muhd Nur Akbar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 28
지난 30일: 179
전체 시간: 527
