주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
My phone is daad
My is daad is 3 year old
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Amit, you haven't given us much to go on here. I assume you're saying the phone won't turn on, is that right?
If that's the case, tell us more. Did anything happen to the phone before it refused to power on, such as being dropped, exposed to liquids, a system update,etc.? How was the battery life previously? Did it take a full charge and last a decent amount of time, or were you having to charge it frequently?
Have you tried a new charging cable and charger, or verified that yours works on another device? How about the charging port; did you examine it carefully for any debris or pocket lint that could be keeping the charger from being inserted fully? Have you cleaned it out carefully and checked for any bent or broken pins inside?
You might want to purchase an inexpensive USB ammeter to see how much power the phone is drawing when it's plugged in; that will help pinpoint whether it's a charging port or charging circuit issue if indeed it isn't getting any power.
If you want to just dive in and start replacing parts, I'd suggest a new battery and a new charging port, then reevaluate and see if that fixes the problem.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Amit Babu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 21
전체 시간: 38
