주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2022년 2월 25일에 출시된 밸브에서 만든 휴대용 게임기, LCD 디스플레이가 장착된 Steam Deck의 수리, 분해 및 문제해결 정보입니다. 모델 번호 1010으로 식별됩니다.
R1 not responsive even after replacing
I recently dropped my Steam Deck (LCD) and noticed that the R1 button seemed to be broken -- it felt loose, and it while it still worked when pressing it from the top, it was no longer "clicking" and was unresponsive when pressed from the side/corner of the console. So opened it up using the guides on this site, removed the R1 button and found that the plastic bar extending to the center of the console had broken off. I ordered a new R1 button from this site and installed it.
To my confusion, the problem wasn't solved. The new R1 button doesn't feel loose but it's still not clicking and it's still unresponsive from the side. So I assume something else is broken, but I can't identify what it is, so I'm wondering if anybody with expertise on the Steam Deck can help me here. I'm happy to order replacement parts and do the repairs myself, I just need to identify what the problem is!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
What happens if you press the “R1” button switch with your spudger? If it still doesn’t want to “click” you most likely need to replace the board together with the switch to get it working (or solder the bad one out and solder a new one in).
If it clicks in fine with the spudger, try to replace the whole button together with the spring!
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanks for the response! If I need to replace the entire board, is there a reliable place to get one? I'm not seeing them at the store here.
I found one on AliExpress: https://www.aliexpress.us/item/325681190...
Unfortunately, it's not cheap. But this should do the job if you are having issues with clicking the actual switch on the board.
댓글 달기
답변을 추가하세요
Michael S 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 56
전체 시간: 56
