주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
New Nintendo 3DS XL로 알려진 Nintendo 3DS XL 2015년형은 2014.10.11에 일본에 출시되었으며 북미에서는 2015.2.13에 출시되었습니다. 대한민국에는 2015.5.1에 출시되었습니다.
New 3DS XL constant error screen
I tried to boot up my 3DS after 1-2 years since I last touched it, when plugged into a charger the charging light only shows up after 10-20 minutes of charging, once I turn it on it works for a few minutes and then starts stuttering and finally freezes at the "An error has occurred" screen, holding the power button doesn't turn it off unless I take the battery out. The blue light goes off briefly before coming back on just before the error screen shows up.
So I've swapped the battery, disabled the wifi, removed the SD card but the error screen still shows up after working for 1-2 minutes
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi!
First: Is the New 3DS XL modded?
Try to get in the recovery menu with doing the following:
turning off the console and holding down L + R + A + D-Pad Up while pressing the power button
Does it work now? If yes, try to update the console and see what happens.
Since it does work for a few minutes, it does sound like software/firmware issues.
Please keep us posted!
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Hi, after updating and leaving it on for about 1 hour it seems like it worked, It stopped freezing!
Booting into the recovery mode to update was one of the options I had in mind but I was afraid it'd freeze mid-update but I decided to risk it.
Thank you very much!
의 공유
Ah glad that it’s solved now! My pleasure :)! Have fun gaming!
의 공유
댓글 달기
답변을 추가하세요
Hsia Hz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 46
전체 시간: 116
