주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Performance Designed Products, LLC에서 제조한 모델 번호 064-015-EU-BL의 PlayStation 3 무선 LED 컨트롤러입니다.
My pc wireless game controller works without touching it
I have 2 of this cheap game controller
이미지
Manufacturer : "ShanWan"
Product : "USB WirelessGamepad "
Device ID : HID\VID_2563&PID_0575\7&17507071&2&0000
Hardware IDs : HID\VID_2563&PID_0575&REV_0200 HID\VID_2563&PID_0575
They were working fine until I transferred my windows from old SSD to new SSD.
When I enter every game I have series of button ( I think they are repeating ) is pressed every 5 to 20 seconds. for example circle back back down start circle even some keys pressed together( up+start+circle).
it is very amazing when I turned the controller off and just dongles attached.
I have tested it on android device and my smart tv and there is no more automatic buttons
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi!
Did you had to install specific drivers for the controllers?
If so, I would remove it and completely reinstall them.
It sound more software/driver related then hardware as they do work fine on other devices and as both are having the same issue.
Remove the software and drivers completely and install the latest again is what I recommend.
Please let us know how that goes!
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
thank you koppi007 but the problem solving accidentally in strange way. ] do not know how :) ;)
의
Weird! But glad that it’s solved :)! Have a great day and fun gaming!
의
thanks. But that did not solve the problem, The main reason was the Epic Game Launcher . I accidentally closed the launcher before testing with tsco controller so if it is open even in system try it will make joysticks problematic!
의
Ah, so that one messed up the driver.. glad that you found it :)! Thanks for sharing this with us! Have a great day!
의
댓글 달기
I had this problem for 2 weeks and trying to solve the problem with AI but after hours there was no hope. but few minutes later when dongle was attached I run the game" streets of rage 4" and after that I accidentally turned on a tsco wireless controller that working with this dongle. The problem completely solved.
I do not sure what makes the problem and what solved it. anyway thank you.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
hamed saffari 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 61
전체 시간: 61
