주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2009년에 출시된 2세대 Toyota Matrix는 소형 해치백입니다. Pontiac Vibe는 GM과의 파트너십으로 인해 기계적으로 유사합니다.
Installing aftermarket USB port
Hi, I have bought an aftermarket USB power port and I was thinking of splicing it into the 12v power port but I'm having a hard time identifying which wire is which. The wire colors are Grey and White with Black strip. Any help will be greatly appreciated.
이미지
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
According to the ground distribution wiring diagram, the white wire with the black stripe is your ground. By a process of elimination, I'm going to state that the grey wire is your 12V power.
Ground Distribution — 2011 Toyota Matrix Base, Automatic Service Manual ~ LEMON Manuals
If you have a test light, that should be pretty easy to tell; connect the test light ground to any piece of grounded metal inside the car, then see which wire makes it light up; I'm betting on the grey.
Okay, I found the power distribution diagram and was able to confirm that yes, grey is power and white/black is ground. Take a look at the middle left of Figure 2 on this page; that shows the cigarette lighter assembly and both wires going to it.
Power Distribution — 2011 Toyota Matrix Base, Automatic Service Manual ~ LEMON Manuals
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank You! These diagrams were exactly what I was trying to look for but for the life of me I couldn't find them.
의
댓글 달기
답변을 추가하세요
Michael Chowaniec 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 48
전체 시간: 48
