주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung은 2022년 8월 10일 "Unpacked" 행사에서 Galaxy Flip 4 제품군을 발표했습니다. 새로운 스마트워치 시리즈인 Galaxy Watch 5 및 Watch 5 Pro와 새로운 Galaxy Buds 2 Pro 시리즈도 함께 발표되었습니다.
Samsung Fold4 mic replacement question
이미지
이미지
이미지
Hi everyone! I have a question about the microphones used the Samsung Galaxy Z Fold4.
At least one of these two microphones has a hissing noise (the phone was exposed to water), so I am planning to replace them. Both microphones are located on the main board.
I have some no-name microphones available (photo 3) that bought from Aliexpress. Judging by their appearance, all three microphones look very similar and seem to have the same contacts. However I am concerned that the two microphones on the Samsung board have different markings, which raises the question: what is the difference between them?
Can I replace both of the original microphones with the ones I have from Aliexpress?
I thought that Samsung microphones with the same contact layout were interchangeable but now I am not so sure. Ch@tgpt keeps giving me conflicting answers.
I found these part numbers although I am not sure if they are (needs to be verified):
3003-001267
3003-001269
I would really appreciate any advice or information.
Thank you!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
You should avoid using random no-name AliExpress digital MEMS microphones if you are unsure of their internal specs, as they often differ in sensitivity, voltage, or frequency response.
Differences Between Board Microphones
  • Markings and Part Numbers: Different markings on smartphone MEMS microphones usually indicate distinct sensitivity ratings (measured in dB), operating voltage, acoustic overload points (AOP), or frequency responses tailored for specific tasks (like noise cancellation vs. primary voice capture).
  • Interchangeability: While many Samsung digital microphones share the same physical pad layout (often 3 or 4-contact land grids), swapping an incorrect spec mic can result in low audio, severe distortion, or persistent background hissing.
Recommendations for Repair
  • Sourcing Parts: Instead of generic parts, look for an exact Microphone for Samsung Galaxy Z Fold4 or verify universal OEM rolls matching the exact sensitivity (-37dB or similar 1.8V digital standards).
  • Water Damage: Hissing noise after liquid exposure usually means water or mineral residue permanently damaged the tiny acoustic membrane inside the MEMS package, requiring a total replacement of the affected component.
이 답변이 도움이 되었나요?
점수 1
댓글 5개:
Thank you for your answer, Adam! What should I do in a situation where I can't find these particular microphones? I can find them in other countries, but at ridiculously high prices (around $8 each + shipping $10-20), and they aren't even available from the local MobileSentrix. Even if I search for "Samsung microphone" on their website, it only shows microphones for a very limited number of models. That's actually what made me think that Samsung microphones might be compatible as long as the pinout matches.
What do professional repair technicians usually do when the required part isn't available locally?
의 공유
When a specific micro-component like a digital MEMS microphone isn't available through local suppliers like MobileSentrix, professional repair technicians usually bypass searching for individual loose parts and pivot to a few proven industry workarounds. Shops that do high-volume micro-soldering rarely buy individual $8 repair components. Instead, they buy strips or full reels of 50 to 100 universal MEMS components from commercial electronics distributors (like DigiKey or Mouser) or direct overseas supply brokers. When bought in volume, these micro-components cost pennies per unit.
의 공유
@neross pin configurations (typically 4-pin, 5-pin, or 6-pin land grid arrays).If a microphone from a widely available model like a Galaxy S20 or S21 shares the exact physical layout and operates under the standard 1.8V digital standard, it can successfully be swapped onto your Fold4 board.
의 공유
Update. I replaced both microphones. One was extremely difficult to desolder, so I had to take it apart piece by piece. It was rusty inside.
Unfortunately this did not solve the problem. The sound came back but the noise did not disappear completely. It became quieter and intermittent.
Also somehow, the sound from these upper microphones when recording video is being routed to the opposite speaker - the one near the bottom microphone. So the stereo effect is messed up.
I guess the problem is related to other components on the motherboard. This board will be installed in a phone that has never been exposed to water and where all other components are known to be working properly. So the problem cannot be anywhere else but the mainboard.
For now, the solution I see for myself is to leave the board without the upper microphones. There will be no stereo recording in video but at least there will be no noise.
If you have any advice or suspect a specific component on the board, please let me know. Thank you.
의 공유
@neross Leaving the upper microphones off the mainboard is a perfectly viable, low-risk fallback option that protects your clean chassis from experiencing background noise, though it will limit you to mono audio capture.Given that the original microphone was severely corroded and required aggressive, piece-by-piece physical teardown to remove, the remaining symptoms point to structural and electronic side effects localized on the mainboard.Why the Noise and Stereo Swap Are OccurringThe Inverted Stereo Routing: In modern smartphones like the Samsung Galaxy Z Fold 4, microphones are often configured as a differential pair or multi-mic array linked to a shared Audio Codec IC or PMIC. If the traces under the destroyed microphone pad were bridged during the difficult extraction, or if the new microphones installed have a slight variance in technical specifications (such as a different digital land grid array mapping or inverted clock/data lines), the phase matrix of the audio chip gets thrown off. The software att
의 공유
댓글 달기
답변을 추가하세요
Neross 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 30
전체 시간: 133
