주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2023년 9월 22일에 출시된 Apple의 최고급 플래그십 스마트폰인 iPhone 15 Pro Max의 수리, 분해 및 문제해결 정보입니다. 6.7형 ProMotion OLED 디스플레이, 새로운 5배 광학 줌 잠망경이 장착된 트리플 렌즈 후면 카메라 시스템, 5G가 특징입니다. iPhone 14 Pro Max의 후속 제품입니다.
iPhone 15 Pro Max Unresponsive
I have an iPhone 15 Pro Max that has endured a fall.
The phone was in a case, and was dropped directly on one of its corners.
Neither the front or back glass appears to be damaged in any way, yet the screen will not turn on and it does not chime when it is plugged into power.
I have tried putting it into recovery mode while connected to my Mac, and it appears to successfully update, but never shows up in the sidebar and the device still does not appear responsive.
I currently do not have the tools necessary to open it myself to test the display cable connection, but I am hoping this is the issue and that this won't be a micro-soldering job.
I do not have Apple Care on the device, and A**le quoted me $850 to repair it.
Any suggestions? Anyone with a similar experience?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
A corner impact with no visible glass damage can still knock the display connector loose or damage the display/board circuitry. Since the Mac isn’t detecting it properly either, I wouldn’t assume it’s just the screen yet.
I’d have a repair shop open it and test with a known-good display and inspect the connectors before paying Apple’s $850 quote. If it was able to update but still won’t boot/display, an iPhone panic log analysis could also help if you can retrieve a panic log.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Roach 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 27
지난 30일: 47
전체 시간: 95
