주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
동일한 모델 번호(A1932)와 EMC 번호(3184)를 사용하는 2018년 후반 MacBook Air의 소규모 개선에 대한 수리 정보 및 안내서입니다. 이 모델은 트루 톤 디스플레이와 약간 수정된 배터리가 특징입니다.
Keyboard issues after battery chane
After replacing the battery I noticed the spacebar, G key, and comma keys are only responsive when I push down hard, the computer heats up, or I'm typing for some time. I assume that some of the adhesive got carried with isopropyl alcohol under the keyboard and is now affecting the keys. The other keys mostly work perfect except a few random ones that I noticed I have to click again. I tried putting a small amount of alcohol under the keys (broke my G key and got it replaced) but it didn't do much.
I really don't want to replace the keyboard, any thoughts or advice would be very much appreciated.
Update (09/15/26)
The battery seems good, its more the keys that are the issue.
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Let's get a better view of things, install this gem of an app! CoconutBattery withe the charger plugged in take a snapshot of the Apps main window posting it here so we can see what it tells us.
의
댓글 달기
답변 1개
가장 유용한 답변
The reason we needed to look at the battery is to see the health of the battery as a swollen battery can press against the keyboard causing issues like you reported.
Yes, the battery looks good so that only leaves how you mounted the battery. The adhesive sheet/tabs should have been thin did you alter them in any way? Did you have a hard time getting the battery out (the pulls didn't pull cleanly for you). Could you have bent the case half? And lastly, did you fully clean the case side of any remnants?
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
1) alter sheets: no not on the new battery at all I just stuck them down
2) definitely had to work to get the battery out and then had to scrape the remnants off after (not of the battery just the adhesive strips that remained)
3) I don't think I bent anything
4) I did my best, there was some adhesive where the battery used to be but I figured putting by putting the new battery in the same spot that it would not cause an issue
의
댓글 달기
답변을 추가하세요
Cashig 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 55
전체 시간: 55
